C-458, "Unable to connect to Authentication Device"...
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys,
    So, I tried everything I could to get rid of this message, including:
    Performing a complete INITIALIZATION, twice (which I do on every used machine I sell)
    Removing the driver in service mode, which then the machine went into code and made me reinstall it
    Called tech support (useless) and he told me that I'd probably have to replace the MFP Board, which I have serious doubts about.
    But I seem to remember having this once before, and I had to go into the Security Settings in service mode (Stop, 0, Clear?) and there was some settings in there
    that had to be changed, but I did not find anything on this machine.
    Any help appreciated!
    OC
  • Synthohol
    Certified Konica Expert
    • 5842
    Re: C-458, "Unable to connect to Authentication Device"...
    stop 9
    vendor mode
      • 23009
      Once you're in service mode > enhanced security mode: Stop 0 Clear > User Authentication > OFF.
      • Oystercopy
        • Oct 2009
        • 623
        STOP 9 did it.. .Authentication Device, turned it off...
        THANK YOU guys!
        OC
        • Blizzoo
          • Aug 2013
          • 608
          Cheaper than replacing a MFB Board. These guys recommending such thing must be working for the sales dept.
          • tsbservice
            Field tech
            • 8020
            He-he tech support 😄
            If that is tech support some of the guys here must be called semi-gods. Hell even I'm better
            • Oystercopy
              • Oct 2009
              • 623
              Exactly right TSB... the guy was just telling me how I'm not "authorized" to get help from him because I didn't buy the machine from them... WHAT??
              And how the C-458 page in my profile didn't have the latest F/W. Yet, the C-558 had the firmware, no problem, so a KM glitch, clearly.
              It's a good thing I have enough knowledge and common sense to fix most of my own issues, because if I had to rely on tech support or training, I'd be just as useless as they are!
              LOL
              OC
