mfp controller download n.g. 284e+
  • tristan.isd
    • Aug 2024
    • 19
    #31
    FW_A5C10Y0-F000-GDU-M1
    • Duplicator
      • May 2022
      • 246
      #32
      Okay good. You have the latest firmware.
      Double check software dip switch 25 is set to hex 60 and dip switch 10 is set to hex 2. If you have to change either one, hit fix and then restart the copier with main power switch under the door.
      Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
      If I helped you out, please give me a thumbs up! It helps my reputation.
