mfp controller download n.g. 284e+
  • tristan.isd
    • Aug 2024
    • 19
    Hello,
    Here is my problem with an ineo+ 284e copier.
    At the start of the week, it lights up with the looping message: “preparing a user box” for hours. unable to print.
    I turn it off and on several times, still the same, then it stays on both bars.
    I tried to update the firmware again, however I get the download ng message on mfp controller.
    I tried to boot by unplugging the hard drive, no improvement.
    I also did the NVRAM reset procedure but when restarting the copier remains on the two bars.
    The SSD is in version 6.05m.
    Do you have any idea what the problem is?
    Thank you for your help
  • Synthohol
    Certified Konica Expert
    • 5822
    have you entered the machine/type after the reset?
    First four digits of the serial number A61F A61G A61H
    [Machine] 4 4 4
    [Type] 1 2 3
    5. Touch [OK],
    • tsbservice
      Field tech
      • 8008
      Oh man reset tool, really?
      First you must check your backup battery voltage.
      If battery is bad and you use reset tool then machine may have a lot of wonderful and unexpected issues.
      Before doing anything else check battery and replace it if flat.
      • tristan.isd
        • Aug 2024
        • 19
        yes the machine type is the correct one by default.
        Serial number prefix A5C2 machine 3 type 2
        The battery voltage is 3.2 Volts on the MFP card
        This gallery has 3 photos.
        • Duplicator
          • May 2022
          • 245
          Did you unset the HDD in service mode first?
          Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
          If I helped you out, please give me a thumbs up! It helps my reputation.
          • tristan.isd
            • Aug 2024
            • 19
            I do not have access to service mode because the copier does not start, it remains on the two bars
            • Synthohol
              • 5822
              can you hold down panel reset to boot into trouble reset?
              • tristan.isd
                • Aug 2024
                • 19
                This gallery has 1 photos.
                • tsbservice
                  Field tech
                  • 8008
                  I would put new Ssbd...
                  • copier tech
                    • 8142
                    Can you enter service mode from this screen, the one with the keypad displayed ?
                    • Duplicator
                      • May 2022
                      • 245
                      It's probably time to just put a new SSD in in it.
                      However, it is possible to get more of an error out of it. If you hold down the power button while turning the main power switch on, depending on the color of the power light, the contents of the screen, and the blue lights on the front there is a chart in a Konica document somewhere that describes what that error works out to.
                      • tristan.isd
                        • Aug 2024
                        • 19
                        no, we cannot enter ce mode
                        • tristan.isd
                          • Aug 2024
                          • 19
                          when pressing the power button, it lights up purple then it turns blue and the four blue dots are on.
                          if I change the SSD I have to contact km? I can't put another SSD from another machine? Do you need programming?
                          • dibyendu2008
                            • Dec 2011
                            • 27
                            Try in firmware update screen right hand side open keypad. From there you can try to enter in service mode and disable HDD or copy data from HDD to EMMC board or try to Logical format of HDD
                            It is SSD or HDD as per my knowledge 284e series have HDD
                            • Duplicator
                              • May 2022
                              • 245
                              Do you have 2 bars or 4 on the screen at that time?
                              If you have 2 bars, and blue lamp is on, it says DIMM failure. Since you had the purple power light it's likely you have 2 RAM DIMMs installed. Try them one by one in the primary slot. According to this one or both may be bad.
                              If you have 4 bars it says you have an MFPB failure but also suggest this could be memory related.
                              Given this additional information I may want to take back my "put an SSD in it" recommendation.
