BH-C-284e, cassette for printing out incoming faxes
  • Hansoon
    • Sep 2007
    • 3390
    BH-C-284e, with fax option FK-511 and optional paper feed deck PC210.
    Customer has the optional PC-210, adding two cassettes to the machine. She wants that the incoming faxes are being printed out from cassette #4 only.
    I cannot find any settings for doing that.
    Any help please?
    Hans
  • kingarthur
    • 1369
    Instead of that, if they're scanning to email, you can set up the device to forward to an email - we usually get the customer to set up a group email, so it goes to more than one person, and only print if the email forwarding fails. It's in the fax settings
    • Synthohol
      Certified Konica Expert
      • 5849
      (3) Print Paper Selection
      (a) Use
      • To set the priority for paper feed tray when receiving the fax.
      Auto Select Selected automatically.
      Fixed Size Printed only on the fixed size.
      Priority Size Printed on size with priority. When the size is not set, it will be printed on the closest size.
      (b) Default setting
      • Auto Select
      (c) Setting item
      • “Auto Select”
      • Fixed Size
      • Priority Size
      (4) Print Paper Size
      (a) Use
      • To set the paper size to print the received document when receiving the fax.
      • To make the setting of [Print Paper Size] enable, set [Administrator Settings] -> [Fax Settings] -> [TX/RX Settings] -> [Tray Selection for
      RX Print] to “Auto.”
      (b) Default setting
      • A4
      (c) Setting item
      • A3 • B4 • “A4”
      NOTE
      • The displays are different depending on the country.
      (6) Tray Selection for RX Print
      (a) Use
      • To select the paper tray to be fixed when printing the received document.
      bizhub C364e/C284e/C224e I ADJUSTMENT/SETTING > 8. UTILITY (ADMINISTRATOR SETTINGS)
      I-187
      (b) Default setting
      • Auto
      (c) Setting item
      • “Auto”
      • Tray 1
      • Tray 2
      • Tray 3
      • Tray 4
      • LCT
      NOTE
      • Tray 3 and Tray 4 will be displayed only when the optional paper feed cabinet PC-110/PC-210/PC-410 is mounted.
      • LCT will be displayed only when the optional large capacity unit LU-204/LU-301 is mounted.
      • Hansoon
        • Sep 2007
        • 3390
        Thanks Synth, should have found this myself.........😳
        Thank you very much.
        Hans
        • Synthohol
          • 5849
          Anytime Hans!
