Fusing unit C300i C360i
  • domovoi3333
    • Apr 2021
    • 6
    Hi guys,
    I need to repair the fusing unit, but I cannot find a parts catalog for it. Could you help me ?
    Thanks.
  • tsbservice
    Field tech
    • 8079
    Re: Fusing unit C300i C360i
    No spare parts from Konica Minolta. What's the problem that fuser should last about million copies.
    • copier tech
      • 8236
      Originally posted by domovoi3333
      Hi guys,
      Thanks.
      Bizhub C300i Fuser Unit.pdf
      • emujo2
        • Mar 2017
        • 1579
        Should last, that's the key..I have 759 fusers going 300K, C458s getting less than 50%..E
        • tsbservice
          Field tech
          • 8079
          Agree that's why I used 'should'. Side question does Konica USA change by warranty fusers failed let's say at half life?
          • domovoi3333
            • Apr 2021
            • 6
            the film sleeve of the fusing unit is damaged. also, I would like to have the lower roller in stock
            • Synthohol
              Certified Konica Expert
              • 5921
              if they fail early they should be under warranty no?
              • Zesti
                • Jun 2009
                • 312
                AA2JR70300 Film Fuser Belt for Konica Minolta Bizhub C250i C300i C360i C450I C550i C650i Upper Fixing Film Sleeves|Fuser Film Sleeves| - AliExpress
