BH C3350i "oil stains"
  • diable69BG
    • Jan 2021
    • 7
    hi everyone, on a copier I have stains like oils and random.
    have you ever seen this?
  • tsbservice
    Field tech
    • 8002
    Re: BH C3350i "oil stains"
    Looks like cockroaches infested machine.
      • 23003
      I don't know the name, but I have seen batches of paper that develop brown "water stains" after heating in the fuser. I believe that it's a chemical residue from the paper making process. It's especially interesting on monochrome copiers. The enduser shows you the brown spots ... and you point out that a monochrome copier cannot ever make brown.
      Also on lesser quality media you can find marks and stains on the unprinted paper in the tray. It's not all perfectly white. =^..^=
      • diable69BG
        • Jan 2021
        • 7
        the paper is of very good quality and I checked, all the pages are blank
        • diable69BG
          • Jan 2021
          • 7
          • Synthohol
            Certified Konica Expert
            • 5814
            on first glance of a low res it looks like used toner stuck in dimples on the transfer belt. ive seen oil spots but they usually have a halo of saturation around the spots.
            can you run 11x17 and see if they repeat?
            • Gift
              • Mar 2011
              • 2459
              I haven't seen any oil stains since the fuser don't need that shitty silicone oil
              Moisture / condensed water can leave temporary marks but this one here, I'm not shure - is it re-produceable? Does it makes a difference in BK/Color mode?
              • diable69BG
                • Jan 2021
                • 7
                the spots disappeared as they appeared ....
                now the belt gears are broken
                what shit this machine
                • suomi
                  • Oct 2008
                  • 152
                  I-Series belt cleaning units clogging up also A4 machines.
