AU205H LOADABLE DRIVER
  • IAN B.C.N.
    • Oct 2024
    • 6
    Hi. Recently I have a Bizhub c364e installed in the office. My boss picked some HID 5427CK Gen1 card readers. I have looked everywhere for the loadable drivers (au205h) or the au205 setup tool with no luck. Where can I find the loadable drivers?
  • Duplicator
    • May 2022
    • 260
    All of those kinds of files (firmware, movie data, pdf data, drivers, ect.) are only found on the "dealer only" sites at Konica Minolta. Your best bet is to contact your local dealer for assistance. If that isn't an option there is a fellow on here that does sell them if you need them. I believe his site is https://www.printerfirmware.co.uk/
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • zunamiwave
      • Nov 2023
      • 22
      What device are you using with the AU-205H for. There are different setting for each card reader. There is what they called Keyboard Wedge mode or CCID but all KM device using AU-205H moving forward specially from the 8series to i series are all using Keyboard Wedge. Provide me what version of firmware you have , the model and I can help you with the loadable driver.
      • IAN B.C.N.
        • Oct 2024
        • 6
        Hi I'm triying to use HID OMNIKEY 5427 CK FW 03.00.0444 on
        KM C545e FW A5C10Y0-F000-G20-M1
        KM C364e FW A5C010YO-F000-G20 M1
        I've installed omnikey workbench there I can see that the reader is on CCID mode.
        Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
        I appreciate everyone's help. Thank you.
        • Synthohol
          Certified Konica Expert
          • 5905
          ck your PMs, maybe something there will help.
          • IAN B.C.N.
            • Oct 2024
            • 6
            Thanks for your help but I tried every file that you previously shared, they didn't work
            I guess the issue is fw related
            • Duplicator
              • May 2022
              • 260
              What is the original issue you are trying to resolve? Do you have an error or does it just not read cards at all? You stated you were looking for device drivers and what firmware your copiers were on.
              • IAN B.C.N.
                • Oct 2024
                • 6
                I'm getting "Unable to connect to authentication device. Check connection and turn
                main switch OFF and ON" after setting billing mode authentication device 2 to CARD. The card reader does turn on but the printer doesn't recognize it, I tried on a KM C545e FW A5C10Y0-F000-G20-M1 //
                KM C364e FW A5C010YO-F000-G20 M1​
                • zunamiwave
                  • Nov 2023
                  • 22
                  So with CCID mode for the card reader, KM stop distributing loadable driver specifically for your model (C554e, C454e,C364e) You actually have to set the card reader to Keyboard Wedge to make it work.
