Konica 654e (mono) SMB V2 with GDU-M0
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I have a couple of 654e mono machines that need scan to folder setup scanning to Windows Server 2019...SMB V1 has been disabled on the server as expected and therefore uses SMB V2.
    Both machines have GDU-M0 firmware which was a recent update.
    Can anyone let me know if SMB V2 would work with this firmware or are there any special software switch settings I need to perform?
    Best wishes
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5847
    ya need to lock 2.0 in with bit sw 219 i think? and in admin mode network smb 2.0 only maybe ntlm too, been a while.
    heres a doc from a helpful guy across the pond.
    SMB Version 2.0 Support-1.pdf
    sent you gdb_m1 but yours may be newer that incorporates this?
    not sure but this works.
    • Duplicator
      • May 2022
      • 246
      As long as the firmware is installed, function version is set to 7, and the SMB authentication setting is set to Kerberos/NTLM v1/v2 it will work.
      These settings work with newer versions of Windows:
      Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
      If I helped you out, please give me a thumbs up! It helps my reputation.
