Scan to mail for human being in C3320i
  • olivenoire
    • May 2021
    • 39
    I do often need to scan to mail in 3 to 4 contacts many times a day. (that it)
    Actually I need to :
    - select the first mail
    - then select "add dest" (useless)
    - Then select the added dest
    - Then validate (useless)
    - Then close the message (useless)
    once again for the third dest etc etc
    Can't find a way to do it faster the same way on Ricoh (simply select multi dest) nor user, admin or CE menu
    Any help?
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: Scan to mail for human being in C3320i
    create a group?
    • copier tech
      • 8169
      Any help?
      You can set multiple scan destinations in: Admin settings>security>restrict user access>multiple address settings>disable.
      • olivenoire
        • May 2021
        • 39
        Hey, thank you.
        Just crazy I did not find it after research.
        • copier tech
          • 8169
          Hey, thank you.
          A few of my clients complained about this "My old machine I could select multiple email contacts"
          I got this setting from Konica Minolta.
          • olivenoire
            • May 2021
            • 39
            Anyway, thank you for sharing!
            • olivenoire
              • May 2021
              • 39
              • tsbservice
                Field tech
                • 8020
                Those were prone to some toner eatings, premature IU failures etc. I will call it success for not doing above and move on. About right time to plan your next A4 color mfp purchase.
                • olivenoire
                  • May 2021
                  • 39
                  you are right
