Minolta Di-450, uneven copies.
Machine has 350K on the clock. Developer 350K, Drum 70K. Copies are uneven from rear to front across feeding direction. See F12-3 Testpattern with inserted piece of testpattern of a healthy machine for comparison.
Tried until now: New corona's and a new drum and played with settings but only minor improvement, cleaned slit glass and discharge lamps ofcourse before. Bias connection seems to be OK but no opportunity to measure yet.
Values are as follows:
Vg -4
Density +3
LD1 current 95, LD1 set 83
LD2 current 94, LD2 set 79
I have to go there Monday morning and will try as a last solution to exchange the laser unit. Any experience with a fogged laserpath in this machine? Any other suggestions please?
Hans
Vg -4
Density +3
Hans
