C-364 won't take firmware....
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys.
    I've run into this kind of thing before, both with the regular 4 series and with the "e" series as well.
    This particular machine is new to me, but the F/W is like a G-072 (very old, possibly original) and when you try to update it, the machine says "USB Stick cannot be recognized" and won't load the F/W.
    I've tried several and older USB sticks but I cannot get it to load. I've re-Iniitialized, reformatted both the HDD and the SSD, tried replacing the HDD. Disconnected it (physically) from the board. Nothing
    has worked.
    The machine has (obviously) been working for years like this, but I hated to resell it with this old of F/W.
    thanks in advance
    OC
  • rrrohan
    • Sep 2011
    • 1977
    Re: C-364 won't take firmware....
    Try ISW method
    Sent from my Pixel 4 XL using Tapatalk
    • tsbservice
      Field tech
      • 7970
      Did you try it leaving front door open?
      • copier tech
        • 8132
        Originally posted by Oystercopy
        Hey guys.
        has worked.
        thanks in advance
        OC
        You are reselling a C364 !?
        Try the 'version up' firmware at least your customer has slightly better hope of scanning etc.
        • Oystercopy
          • Oct 2009
          • 623
          [QUOTE=copier tech;1926914]You are reselling a C364 !?
          I don't know what the version up F/W is.. and I've never done the ISW method before.
          Yes, the machine is otherwise in good shape, and just selling it on Craigslist, not through my company.
          • copier tech
            • 8132
            [QUOTE=Oystercopy;1927531]
            • Oystercopy
              • Oct 2009
              • 623
              [QUOTE=copier tech;1927533]
              I just read through the procedure in the SM regarding the ISW, and I'm confused. I don't know which "folder" they want me to create to load the F/W files in, so the machine
              can upload it?
              • copier tech
                • 8132
                [QUOTE=Oystercopy;1927553]
                can upload it?
                Have have a read of this bulletin.
                Version Up Firmware Technical Information Rev4.pdf
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  Well, here in the states, the latest F/W for the non-e machines IS G00-72. You can find later special F/W but those are for specific issues, usually for specific customers or those with the exact same specific issues and we never install those unless it addresses the specific issues the customer has.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
