Bizhub 363 Scaning quality problem
  • dan4o
    • Sep 2018
    • 12
    Hi all,
    i have BH 363 on 470k copies.
    I have a problem with copy.
    The copy is so poor, no dark and the original light lines missing or not present on the copies.
    When I'm printing from computer, everything is ok, all text lines are in good quality, but when I'm copying the copy is so poor.
    I attach the pics.
    Please help me to solve this problem, otherwise I have to throw away the machine.
    I clean all mirrors.
    I have no ideas how to fix this problem.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub 363 Scaning quality problem
    That's not that bad. Does darkening the copy settings not help. If it does just lock that in as the default copy setting
    Sent from my Pixel 4 XL using Tapatalk
    • dan4o
      • Sep 2018
      • 12
      No, the Darkening from menu not helped. The copy from attachment are on full dark from the menu.
        • 23010
        I suspect that the optics are still dirty somewhere. There are three mirrors, the slit glass both sides, the shading plate, the lamp & reflector, & the front of the CCD lens. I've also seen the backside of the CCD lens and CCD array get dirty. I believe that this machine has a removable black plastic cover to access the backside of the lens and array. Just take care not to change the CCD focus/alignment.
        Take a closer look at the optics. =^..^=
        • tsbservice
          Field tech
          • 8052
          Can you post copy samples without darkening them? Did you make stabilization plus gradations?
          What toner - original or compatible?
          • dan4o
            • Sep 2018
            • 12
              • 23010
              Regardless of the crappy toner, it's still an optical or image processing issue. =^..^=
              • femaster
                • May 2011
                • 1519
                Clean everything, then run gradation adjustments. This should at the very least improve the output, if not getting it back to normal.
                • rrrohan
                  • Sep 2011
                  • 1977
                  is it a fluro exposure lamp or the LED style?
