C454e blue spot
  • daszmu
    • Mar 2019
    • 1
    C454e blue spot
    Hello,
    We have a Konica Minolta C454e, a blue spot appears on appr. every onehundred's print. I have replaced the blue drum unit, cleaned the belt and the DV unit.
    Do you have any other suggestions, what else can I do?
    I attached a photo of the print.
    Thank you for your answer in advance.
  • Gift
    • Mar 2011
    • 2459
    Re: C454e blue spot
    Originally posted by daszmu
    Hello,
    perhaps the dev unit itself or the cooling airflow/filters needs to be checked or replaced
    • tsbservice
      Field tech
      • 8053
      Re: C454e blue spot
      Post total counter and consumables life. I suspect your fault is following dreaded cyan developer depletion discussed here numerous times.
        • 23010
        Re: C454e blue spot
        Those look to me like color registration patches. I think if you look at the primary transfer belt you'll probably see a poor belt cleaning issue. If yes, check the primary transfer belt cleaner unit. It's probably backed up. Also check the primary transfer spout, waste bottle, and clean the primary transfer alienation sensor. It's on the back wall of the machine behind the belt, and monitors the movement of the color primary transfer rollers. Photo? Yes:
        • femaster
          • May 2011
          • 1519
          Re: C454e blue spot
          That was exactly my thought when I saw the pictures. I'll second the idea of a cleaning issue with the transfer belt.
          • tmmdmmm
            • Apr 2021
            • 173
            Re: C454e blue spot
            x3 Cleaning blade. Try running 15 or so full bleed halftones with M or K immediately followed by a few w/ density closer to 0. I imagine you'll see a streak of whatever color it is
            • Sysco
              • Mar 2010
              • 43
              Re: C454e blue spot
