HDD Error
  • druckerteam
    • Oct 2015
    • 28
    [Error Code] HDD Error
    Afer changeing the HDD from a bizhub C754e we need a new firmware for the machine.
    Could anybody send me the firmware for C754e ?
    Regards, Paul
  • emujo2
    • Mar 2017
    • 1579
    Re: HDD Error
    The replacement of a HDD does not require new firmware..Movie data yes, but if you need f/w it's not because you changed the HDD. E
    • copier tech
      • 8200
      Re: HDD Error
      Regards, Paul
      Hi Paul, we're happy to help with you firmware/animation files should need them. We can be contacted at the links below.
      • tmmdmmm
        • Apr 2021
        • 173
        Re: HDD Error
        Its been a while, but doesn't a logical format for 654/754 Require a firmware upgrade? Or is that just Mode1-9 overwrite all data? Remember it being different than 554 and below
        • druckerteam
          • Oct 2015
          • 28
          Re: HDD Error
          Good morning.
          We had to change the HDD. But with another HDD we get also C-D012.
          In the past a firmware upgrade fixed this issue.
          So we searchig the firmware for C754e.
          Regards, Paul
          • femaster
            • May 2011
            • 1519
            Re: HDD Error
            Regards, Paul
            Looking at the trouble code in the service manual, it looks like you might actually need the firmware. I've apparently never replaced a hard drive in a similar model machine, as I know that I have never needed to do firmware (only movie data [and PDF/A fonts on certain models]) after a hard drive replacement, and I've replaced a lot of them. Have you at least tried the first part of the procedure below and done the logical format of the drive to see if the error code goes away?
            CD012
            Trouble type
            Mount error due to hard disk being unformatted
            Trouble code
            CD012
            Rank
            C
            Detection timing
            • The hard disk that has replaced an old one is not logically formatted.
            Trouble isolation
            Relevant electrical parts
            Hard disk
            (2)Procedure
            Step
            Action
            Control signal
            Location of electrical components
            1
            Logically format the hard disk and then upgrade the firmware.
            2
            • REGSIS
              • May 2016
              • 435
              Re: HDD Error
              I didn't change HDD on any machine above 55ppm, but on lower models, I always do physical format first, and then logical format.
              Error code is normal when the disk is new or removed from PC.
              P.S. Physical format may last up to an hour and a half.
