Battery of a Bizhub 4750/4050
  • Ornitorrinco Mordaz
    • Nov 2024
    • 16
    Does anibody knows how to change a battery of a bizhub 4750/4050, i believed the problem is related because the printer does not retain date and time after a restart, i learn that in these machines the date and time affects them a lot, in another thread someone said that it coud be the battery. The original problem on this printer is that it came out with an error code C-EEE1, in the service manual just says to check the connectors of the MFP, and it doesnt say how to change de battery.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Dead batteries is very common on this model and you know when the time is lost. They are very easy to change. I ended up buying batts from Digi-Key
      • Nov 2024
      • 16
      Do you know how to change them? We bought a whole shipment of these machines it would be useful to know
      • copyman
        Owner / Technician
        • Sep 2005
        • 4700
        Remove door (see attached). You will see small battery on board, carefully use small tool to pop out battery. Make sure to hold battery holder when removing battery so you don't break the solder joints.
          • Nov 2024
          • 16
          this applies for the 4752/4052 aswell? i dont see the battery
