Bizhub 287
  • anor Anoar
    • Nov 2024
    • 24
    Bizhub 287
    Error code C-5360
    Bizhub 287
  • anor Anoar
    • Nov 2024
    • 24
    repair bizhob 287
    C- 5360
    • femaster
      • May 2011
      • 1519
      Sorry, I have no experience with the CU-101, so all I can give you is the details of the service manual. Problem lies with a fan in that unit.
      C5360: Clean unit fan failure to turn (When CU-101 is installed)
      Trouble detection condition - The fan lock signal remains HIGH for a predetermined continuous period of time while the fan is turning.
      Relevant electrical parts:
      • Exhaust fan/1 (FM14)
      • Exhaust fan/2 (FM15)
      • Clean unit drive board (CUDB)
      • MFP board (MFPB)
      Procedure:
      1. Check the connector between CUDB CN1-MFPB CN43E for proper connection and correct as necessary.
      2. Check the connector between FM14-CUDB CN3, FM15-CUDB CN2 for proper connection and correct as necessary.
      3. Check the fan for possible overload and correct as necessary.
      4. FM14, FM15 operation check
      • Load check: Check code42, Multi code 5
      • Control signal: CUDB CN3 (FM14), CUDB CN2 (FM15)
      • Location of electrical component: 27-L (FM14, FM15)
      5. Replace the defective fan. (FM14/FM15)
      6. Replace CUDB.
      7. MFPB F16E conduction check
      8. Replace MFPB.
      • tsbservice
        Field tech
        • 8051
        Just make sure clean unit is uninstalled in service mode
        • anor Anoar
          • Nov 2024
          • 24
          How ???
          • anor Anoar
            • Nov 2024
            • 24
            how is the way can you explain to me
            • Synthohol
              Certified Konica Expert
              • 5891
              system 2 maint mode.
              5.16.31 Cleaning Unit Setting (1) Use
              • Use this feature upon the optional clean unit CU-101 set-up.
              (2) Default setting
              • Not Installed
              (3) Setting item
              • Installed
              • Not Installed
              simply refer to your service manual regarding procedures.
