KMBH754 prt speed mem upgrade
  • digicor
    • Jul 2008
    • 1159
    will upgrading the mem on a c754 speed up larger file's sent to print? clien periodically sends large plans 10-15 pages on 11x17 and it takes 15min to spool and print, otherwise the print is fine, the driver is the KM c754 pcl they are running win10
    where is the buffer speed if there is one, located? i am more familiar with ricoh , the buffer speed has an effect on the prt speed in some cases
    i looked in the admin tools, prnt sections, and in the web access..
    thanks for any insight
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: KMBH754 prt speed mem upgrade
    Print jobs spool faster on the copiers HDD.
    Make sure in printer settings that it is set to allow it
    (Spool print jobs to hdd)
    Also I have always found the PS driver to be faster and show better color. YMMV
    • digicor
      • Jul 2008
      • 1159
      printer settings in web access or can this be found on the panel level?or in service mode?
      • Synthohol
        • 5892
        admin mode.
        Printer Settings Basic Settings
        Spool Print Jobs in HDD before RIP I.6.5.1.(4) Spool Print Jobs in
        HDD before RIP
        • emujo2
          • Mar 2017
          • 1579
          Adding memory will not help as this RAM is used for the LK options only.
          • emujo2
            • Mar 2017
            • 1579
            I have seen a few issues that cause massive delays in spooling and printing..1st if the files are being printed by IE, edge, chrome ect.. instead of DC reader, and if the files are true PS files. open the see whats printing viewer for the driver. Send a job and watch the spool process. If the file size shows 3KB (just a guess) and the spool size hits 3 MB then the PCL driver is having to do way to much work. Switch to the PS driver. For jobs that try to print via a web browser, just change the Open with default. E
