konica 7033 toner dust
  • mdm7266
    • Dec 2007
    • 99
    hello there!
    i have a problem on konica 7033. It is whenever i make multiple copies, Toner accumulates easily on charging grid, thats why my copy quality deteriorates to light copies. I'm always on a stand by to clean it. I already replaced the developer, clean the charge, transfer/separation and the toner duct (the black one that is attached under the laser assy). the vacuum/exhaust fans are rotating/functioning. Could this be an adjustment on data? (HV1, transfer/separation, dev bias, charging grid, etc?). this problem does not happen before even i make many copies. But now it is my problem.
    The Boards, laser assy inside the scanner assy easily accumulates toner.
    ( I cannot make 100 continous copying without cleaning the charge wire.
    thanks
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Replace the lid on the developer assy. The seal on the front is warped allowing toner to puff out and pollute the grid and charge assy. Change this every 2nd or 3rd PM and your machine will run clean I think the part cost about $20.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • dogsbody
      • Jun 2007
      • 289
      Also if the foam seal where the waste is fed back into the dev tank is damaged/missing the charge corona will get filthy with toner. if this is the case you can seal it with a foam strip cut to size or wrap it up with electrical tape.
      cheers
      The force will be with you always.
