Device certificate
  • kingarthur
    • 1362
    Device certificate
    Has anyone noticed, that when you do a "Clear all" on a KM device, it now also wipes the device certificate, so you can only access via Pagescope by putting "HTTP" instead of "HTTPS", even then, I can only connect via a laptop straight to the device, via "HTTP" go to admin mode create a new certificate, it then works. However, I've got a C458 that even when connecting straight to it with a laptop, I can only connect via "HTTP", but when I input the admin password it switches to "HTTPS" and locks me out - any ideas why, or how to resolve
  • tsbservice
    Field tech
    • 8019
    Try Pale moon browser or via copier panel turn off SSL version.
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      Create another automatic certificate, in administrator options, it's very easy
      Field technician since 1994
      • tsbservice
        Field tech
        • 8019
        He can't machine is forcing him out from Admin mode.
        • kingarthur
          • 1362
          If I could get into admin mode, I would, as soon as I enter the admin password - i get kicked out
          • Synthohol
            Certified Konica Expert
            • 5829
            id copy the address book and initialize the nework in service mode and try again.
            • kingarthur
              • 1362
              I actually managed to do it in Admin mode, then Security, didn't need to copy the address book - thanks for the suggestion
              • John Kaufmann
                • Sep 2013
                • 114
                Originally posted by kingarthur
                I actually managed to do it in Admin mode, then Security, . . .
                And did the resolution have something to do with Pale Moon (as tsbservice suggested)?
