Looking for a bootup converter
  • JC Andres
    • Dec 2023
    • 40
    Hello, could someone help me or send me the bootup converter file? I can't find it anywhere thankis!
  • Synthohol
    Certified Konica Expert
    • 5891
    here ya go. bootscreen.zip
    • rrrohan
      • Sep 2011
      • 1977
      i stopped doing boot screens on the newer series as its only visible for a couple of seconds
      • aries
        • Dec 2024
        • 4
        What does the "bootup converter" do? Apologies for my ignorance, but I'm just not familiar with this...
        -J
        • aberock
          • May 2022
          • 129
          -J
          convert image into bit and make it appear when you boot the machine . can be use to promote company when booting for a few second
          • Synthohol
            • 5891
            download the zip and read the word doc.
            it explains everything.
            • aries
              • Dec 2024
              • 4
              Ah gotcha, thanks!
              • tsbservice
                Field tech
                • 8051
                True that for bootup screen. More useful is wallpaper it's like windows background.
                • kingarthur
                  • 1385
                  I've forgotten how to create the image for the screen background, everything I try, it says the file is "NG" - bootscreen isn't a problem, I can sort that
                  • tsbservice
                    Field tech
                    • 8051
                    WALLPAPER.png in root of USB and import from Admin-system settings-custom display settings-main menu display settings-register
                    • kingarthur
                      • 1385
                      That could be where I've gone wrong, I thought I'd done it previously in service mode and uploading "machine image"
                      • tsbservice
                        Field tech
                        • 8051
                        Yes Sir it could be a bit tricky. I removed almost all buttons from our bizhub and company logo seats nice and clean as wallpaper
                        • kingarthur
                          • 1385
                          Thank you tsbservice, that worked brilliantly, if i knew how to boost your rep I would. Hope you have a great Christmas
                          • tsbservice
                            Field tech
                            • 8051
                            kingarthur Same to you and your family
