Firmware & Movie Data for c364e
  • aries
    • Dec 2024
    • 4
    Hey Guys -
    Might someone have the latest firmware and movie data for the c364e? It's been a few years since mine was updated.
    Here is what is currently loaded on it in case that is helpful.
    Thank you!!
    -J
    ROM Version
    MFP Card Version A5C10Y0-F000-GDN-M1(00)
    MFP Controller BOOT Program A5C10Y0-1E00-G00-05(00)
    MFP Controller Linux Base Linux-2.6.26.8-rt16
    MFP Controller Kernel Program A5C10Y0-1C00-GC4-76
    MFP Controller SubSet A5C10Y0-1F00-GGV-M1(00)
    MFP Controller A5C10Y0-0100-GDN-M1(00)
    Operation Panel Message Data A5C10Y0-8100-GCN-M0
    Fax Board Controller1 A22M0Y0-4000-GD0-12(00)
    Fax Board Controller2
    Fax Board Controller3
    Fax Board Controller4
    Engine Parameter A5C10Y0-0054-G00-01
    Engine BOOT A5C10Y0-0055-G00-00
    Scanner A5C10Y0-0023-G00-33
    Printer A5C10Y0-0050-GC2-31
    ADF A3CE0Y0-0024-G00-16
    Finisher A3EP0Y0-0071-G10-05
    RU
    ZU
    Panel CPU A55V0Y0-8900-G60-00
    DSC1
    DSC2
    Loadable Device Driver1
    Loadable Device Driver2
    SD
    Voice Data
    Movie Data
    Dictionary Data
    OCR Library
    Panel Sound Data A5C10Y0-C200-G00-00
    MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01
    MFP Controller PIC Image Parameter A5C10Y0-8A00-GC0-06
    MFP Controller System A5C10Y0-1000-GDN-M1(00)
    MFP Controller Print Controller A5C10Y0-3000-GDB-44
    MFP Controller Print Controller Font A5C10Y0-3F00-GCF-40
    MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81
    MFP Controller MIO A5C10Y0-5000-G21-W8(00)
    MFP Controller PIC A5C10Y0-8200-GD6-B2
  • Synthohol
    Certified Konica Expert
    • 5813
    your FW seems up to date, it is a discontinued (3/2023) machine after all.
    are you missing movie data or just trying to find the latest which you may already have.
    • aries
      • Dec 2024
      • 4
      Ok great. Just wanted to ensure I was on latest and if not, obtain the latest. I do not have the movie data at all, actually.
      It would be helpful to obtain copies of this firmware and movie data -- I can load the movie data, and keep both as backup just in case.
      Thanks!
      • copier tech
        • 8136
        There is a later version available, GDU-M1 See attached & we can supply the movie animation date should you wish to keep a copy as you say for future use.
