KM 284e - Fail to reflect engine data
  • aberock
    • May 2022
    • 129
    Hi guys, recently our new guy in company try to replace prcb due to weird code happen when booting.
    So what he did is backup the engine data and replace new prcb but after place new board machine still show save data instead of reflect data.
    Is there any method we can save the machine? Now we can't save or reflect engine data it show NG
    Machine boot up normally but all engine didn't work. Silent machine
    Thanks.
  • Synthohol
    Certified Konica Expert
    • 5892
    what happens when you try to install firmware?
    • aberock
      • May 2022
      • 129
      Stuck at 3 bar screen. Won't boot into FW screen
      • Synthohol
        • 5892
        if you have the firmware and movie data you have not much to lose by running the reset file 3 times and see what happens then.
        • Synthohol
          • 5892
          also when doing the backup before board replacement, all accessories and options are supposed to be removed first.
          • aberock
            • May 2022
            • 129
            Still no luck sir.
            Run the reset file still won't take the FW.
            • tsbservice
              Field tech
              • 8052
              You may have corrupted data. Can you enter service mode via TR?
              • aberock
                • May 2022
                • 129
                Yes sir able to enter service mode
                • tsbservice
                  Field tech
                  • 8052
                  Can you clear all data? Also I would try to uninstall HDD and then disconnect it before boot.
