After SSL set to TLS 1.0 ERR_SSL_VERSION_OR_CIPHER_MISMATCH
  • christian8220
    • Jul 2020
    • 53
    I played around with some SSL settings in the webinterface on my Konica Minolta C454E. I changed the SSL settings to use TLS 1.0. Now I cannot connect to the webinterface as administrator anymore. I get the message: “ERR_SSL_VERSION_OR_CIPHER_MISMATCH” I tried to change my browser settings to allow me to connect to a webserver with TLS 1.0. Unfraternally, it didn’t work. Is there a way to reset the network settings without using the webinterface? I tried to look in the administrator menu on the printer. However, I was not able to find anything.
  • Synthohol
    Certified Konica Expert
    • 5835
    someone recently posted a browser that works with 1.0 here in the konica forum.
    • christian8220
      • Jul 2020
      • 53
      I tried to search for it. However, I wasn’t able to find it. Let me know if you find it thanks
      • tsbservice
        Field tech
        • 8019
        Pale moon.
        • Synthohol
          • 5835
          thanks^^^
          can confirm (with a quick security exception checkbox) it can connect to both of my ic-413s that run XP 1.0
          • christian8220
            • Jul 2020
            • 53
            Thank you for your advice. I was able to connect to my Konica Minolta by the web interface with the browser you recommended. I later found out that by resetting the network setting in the service menu I was able to get back to the default setting again.
            • Duplicator
              • May 2022
              • 246
              Pale moon.
              That is way easier than that I was doing.... I had virtual machines with old versions of Firefox. Also some portablized old versions of Firefox as well.
              Looks like I can dump those and get some disk space back.
              Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
              If I helped you out, please give me a thumbs up! It helps my reputation.
