Residue right side of prints
  • positiveg
    • Jun 2018
    • 299
    Hi there guys me again. I don't know if my machine is just having a bad week lol.
    What would be causing this? I did change the developer powder thanks
    And it's not just on large sheets this is a letter size paper
    Sent from my SM-A325M using Tapatalk
  • tech_in_greybruce1
    • Jan 2021
    • 8
    Re: Residue right side of prints
    Look at the fuser rollers then work backwards from there
    • Quatro
      • Dec 2015
      • 78
      [ATTACH]50715[/ATTACH]
      Hi,
      I think you have some issue on main charge unit arcing.
      • lartis.aineias
        • 78
        I believe is the bk drum!
        Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
        • Quatro
          • Dec 2015
          • 78
          do you mind to share the model of the machine
          • Synthohol
            Certified Konica Expert
            • 5822
            Don't take this personally but what I'd like to know is whatever happened to stopping the machine at different points of the copy process and see where the problem develops
            If the dots are there before the fuser that eliminates the fuser.
            Run a few blank sheets and If the dots are still there I'd look at the transfer belt cleaning.
            Pull the belt and see if the dots are on the belt before or after the image.
            • patrickjlc
              • Feb 2015
              • 225
              What kind of machine is it? Did you check the drum ot transfer belt?
              Sent from my motorola one 5G UW using Tapatalk
              • positiveg
                • Jun 2018
                • 299
                It's a C454. Sorry for not mentioning that earlier. I'll take a look at the drum and transfer belt to see if there's any residue plus stopping the job to see possibly where they may be coming from
                Thanks all
                  • 14701
                  It looks like a dev unit problem. Did you replace the entire dev unit or just the powder?
                  Try a brand new dev unit
                  • patrickjlc
                    • Feb 2015
                    • 225
                    You can try printing the paper long ways instead of landscape and see if it shows up. To me it looks more like a drum unit has gone bad. How many prints the machine has?
                    • CopierNerd
                      • Feb 2015
                      • 207
                      I think these spots are on drum unit. Check transfer belt unit.
