konica minolta 1060L jam 1701
  • dion
    • Oct 2014
    • 3
    [Jamming] konica minolta 1060L jam 1701
    hi everyone,
    haVing trouble with a c1060L.Jam 1701 from tray 1 or 2 and often from bypass.Not often from LU.
    Feed rolls tray1-2 almost new,testing with multiple quality of paper(80-170gr).
    i've changed 2 drive feed clutch(between each other)but nothing happent.
    Tried to speed down from tray1-2(no result).The paper stopped at registration area.
    ANY IDEA??????
    Best regards!
  • lartis.aineias
    • 78
    Re: konica minolta 1060L jam 1701
    Originally posted by dion
    hi everyone,
    ANY IDEA??????
    Best regards!
    Hello Dion.
    Try to remove bypass , disable dipsw 36-0-0 and try to print from tray 1! there is a possibility that the bypass separation plate has been damaged.
    however look at the pinch rollers at the adu input,
    there is a clutch on the shaft!
    Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
    • wjurls
      • Feb 2017
      • 501
      Might be time to remove the registration unit from the machine and give it a once over. The shaft bushings can get gummed up and cause jamming and/or registration problems.
      • lartis.aineias
        • 78
        hi everyone,
        ANY IDEA??????
        Best regards!
        Γράψε λάθος το προηγούμενο ποστ δεν διάβασα το registration.
        Πάρε το registration στο χέρι , καθάρισε τα boushings και τους άξονες και δες προσεκτικά πηπως έχει πάρει κόλλα κάτω από τις λαμαρίνες (αυτό μόνο εφόσον η μηχανή τυπώνει αυτοκόλλητα)
