KM Press C3070 Jam Code J7847 on RU-518 De-curler section
  • FixitYo
    • Sep 2020
    • 15
    Troubleshooted this code and found RU Controller board with ICP 2 blown, same problem on this machine several months ago. Checked harness and no short to ground and connectivity from end to end on harness. Motor is good swapped out with M5. Anybody else come across this? Thanks in advance!
  • tsbservice
    Field tech
    • 8064
    Re: KM Press C3070 Jam Code J7847 on RU-518 De-curler section
    Not knowing these but I would start cutting all cable ties in question. Just a thought.
      • 23010
      I've seen the vertical path motor repeatedly blow the ICP in the PRCB.
      I would replace your motor and RU Controller as a set. =^..^=
