W10, USB-printer install
  • Hansoon
    • Sep 2007
    • 3388
    Customer has a computer with W10. His old USB-printer broke down, so he wants to install a new printer I supplied to him. When attaching the USB cable coming from the printer to the computer, it shows a reaction in the sys-tray, but installing is not taking place.
    When I try a manual install, everything is fine until it comes to a window asking for the admin pass word. The customer lost this admin password and there is no administrator any more available.
    Is there a workaround for such situations? Any help please?
    Hans
  • Synthohol
    Certified Konica Expert
    • 5842
    first id just change the admin password, its not hard especially when you already have a logon.
    if they are restricted on their own computer then either print from one they are or save to a PDF and print it from a flash drive.
    its unacceptable to own a computer you cant modify to the least of all adding a printer.
    • Duplicator
      • May 2022
      • 246
      Hans
      I hate to admit this but.... I drive around with a WinPE live "cd" (it's really a flash drive) so that I can reset passwords on computers that customers have lost the passwords to. It is a little harder on macOS but that's a story for another day....
      I completely agree with Synthohol last statement about owning a computer and not being able to even add a printer.
      Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
      If I helped you out, please give me a thumbs up! It helps my reputation.
      • Hansoon
        • Sep 2007
        • 3388
        OK, but how? Complicated procedure? 😎
        Hans
        • Synthohol
          • 5842
          Get the files you need to create WinPE media
          1. Download and install both the Windows ADK and the Windows PE Add-on. When you install the ADK choose, at minimum, the Deployment Tools feature.
          2. After you've downloaded and installed the ADK and Windows PE add-on, you can create bootable Windows PE media.
          3. see #4
          4. https://hashnotes.tech/part-2-create...ll-windows-adk
          5. good luck!
          • Duplicator
            • May 2022
            • 246
            I'm assuming the forum rules mention posting links to warez or hacking items so I'll leave you to the Google-fu to find them all.
            Anything with Bitlocker turned on (such as some new Windows 11 PCs) will prevent you from doing this but generally there are a few methods:It would be worth looking into one of the Ventoy based "live CD" sets. Medicat is a popular one. It has every tool you could ever want to work with PCs. It's basically the Hiren's Boot CD for 2020+.
