364e not scanning when faxing
  • patrickjlc
    • Feb 2015
    • 225
    Got a 364e that when I try to fax, it doesn't pull the paper thru the scanner. It says scanning and after a second it goes to scan/fax page where you do fax/ email/ smb/ etc.
    Copies work perfect on the feeder. Tried unsetting and setting up different fax units and still the same.
    Have a couple 454 and 554 with faxes and work fine, sometimes I get a dud fax board.
    Any ideas? Thanks.
    Sent from my motorola one 5G UW using Tapatalk
    • 23010
    Re: 364e not scanning when faxing
    Does the DF work for copying? =^..^=
    • patrickjlc
      • Feb 2015
      • 225
      Yes, works perfectly
      • tsbservice
        Field tech
        • 8053
        What happens if You're faxing from the glass? Will it send?
        • patrickjlc
          • Feb 2015
          • 225
          From the glass it works, but not from the DF
          • patrickjlc
            • Feb 2015
            • 225
            Yes, from the glass faxing works. I dont have a phone line connected that is why it gives me the no line error.
            • patrickjlc
              • Feb 2015
              • 225
              Its working now. I formatted the HDD and did the firmware and everything is working now.
              Guess previous owner deleted everything and that us why it had issues.
              Thanks for the help.
              • tsbservice
                Field tech
                • 8053
                Thank You for leting us know.
                • trscolin
                  • Aug 2012
                  • 21
                  Make sure you set the marketing area in service mode from JP. It gets reset after machine is wiped. If you don't you will have intermittent faxing issues.
                  • patrickjlc
                    • Feb 2015
                    • 225
                    Thanks, there are two more JP on the marketing area that i switch to US also. Only thing, are Konica slower than Kyocera regarding faxes? Because I swapped from a Taskalfa 520i to this Bizhub and to a 454e, and on the 520i sending/receiving/and result reporting is right away, compared to like 1-2 minutes on the BH...
