As described, I took the HV board out. Everything behind it seems to be in order. I put the board back and made sure that all the springs were correctly located. I turned on the printer and made a test print. However, I didn’t change anything and the TCR percentage was still 0 for the three-color toner. I used a voltmeter to check the voltage on the four-output pins in the top (white, blue, red and yellow). I got 0,31 volt (VDC) on all outputs. So, for me it seems like the HV board is sending the correct power (see picture)
I took the top cover of the printer to access the toner. I removed the toner and opened the slider. As the picture shows it looks like the developer unit is getting toner from the toner above.
Could it be that three developer units just stopped working after the printer was moved to a new location? I have no clue on how they moved it. Could something stop working if the printer is put on the side?
I just still don’t get it that the black/white works fine. So, I guess it must be something that the three colors have in common?
Thanks for the help so far. Let me know if there is anything I should check that can get me closer to a solution or at least figure out what the problem is.
