bizhub C4050i Won't update firmware
  • copyguy69
    • Feb 2016
    • 94
    I have the files on the flash drive correctly and following the instructions, but the machine won't load the files. The machine can see the files so I know the drive and port are working. I did turn off the security settings to allow the firmware to be loaded. Am I missing something? Any suggestions are welcome. Thanks in advance
    copyguy69
  • Synthohol
    Certified Konica Expert
    • 5807
    Re: bizhub C4050i Won't update firmware
    This may sound silly but you are holding
    Down the yellow button with the red dot while turning on the machine right?
    If not, there ya go
    And the stick only has the folder FW0000xx on it right?
    Drive is 8gb or smaller right?
    Sometimes it's just the little things.
    • tsbservice
      Field tech
      • 7986
      If not, there ya go
      Totally agree, one note... works with 32GB thumb drive without problem on new i-series.
      • copier tech
        • 8131
        copyguy69
        As Synthohol said but we have found sometimes it may take a few attempts to accept the FW. Usually a reboot & try again it will work.
