Konica Accurioprint C2060L IC 417 E300 reinstall
  • senchi
    • Jun 2020
    • 16
    Hello,
    I have a problem with an IC 417, after reinstalling the software, i am getting 00, ready for reception, but the controller doesn't show up in the main screen, the webui is accessible.
    I used an old image to no avail, i tried to reinstall but the installer looks for a second system dvd that i don't have, can you please send me the full software images?
    Edit: i am also getting an error on screen:
    I2c-algo-ich: ich_gpio sendbytes: error - bailout
    kvf_driver_init : registered 18 device numbers
    I tried reseating pci card and ram without results
    Thank you very much!
  • senchi
    • Jun 2020
    • 16
    Bump
    • Synthohol
      Certified Konica Expert
      • 5891
      isnt there a bit switch to tell the machine to look for a fiery?
      • Synthohol
        • 5891
        11)Turn ON the main power switch of the image
        controller.
        Note:
        Make sure the machine is on before you turn
        on the image controller.
        Step
        1. Enter Service Mode.
        2. Note:
        Refer to procedures in the Service Manual to enter into the Service Mode.
        3. Touch the “System Setting” key.
        4. Touch the “Software DIPSW Setting” key.
        5. Set the following DIPSW settings.
        40-7: OFF(0)
        55-4: ON(1)
        6. Touch the “Return” key and then touch the
        “Exit [SERVICE]” key.
        7. Touch the “Exit [UTILITY]” key.
        8. Turn the Main power switch and the Sub
        power switch OFF first and then turn them
        ON.
        • Synthohol
          • 5891
          sent you a PM
          • senchi
            • Jun 2020
            • 16
            controller.
            Note:
            Step
            2. Note:
            40-7: OFF(0)
            55-4: ON(1)
            ON.
            The machine was working well until the controller went down, i will check this asap, thank you!
            • senchi
              • Jun 2020
              • 16
              sent you a PM
              thank you very much!
              • senchi
                • Jun 2020
                • 16
                controller.
                Note:
                Step
                2. Note:
                40-7: OFF(0)
                55-4: ON(1)
                ON.
                I checked the settings and they are corrects, i changed the hdd and the same problem arised, i used an old image that should be working, the links that you provided are the same that i already had, and whenever i try to install from them directly or create a bootable usb it asks for a 2nd system cd.
                • Synthohol
                  • 5891
                  have you tried the user software disk as #2?
                  i recall older fierys needing it for the software to embed in the webpage for the downloads tab.
                  couldnt hurt to try?
                  • senchi
                    • Jun 2020
                    • 16
                    I tried before without success, i managed to reinstall the fiery using version 1.0 even though i canceled the installation when it asked for system cd 2. Now it is working fine. Thank you very much!
                    • senchi
                      • Jun 2020
                      • 16
                      Also it looks like there is indeed a system software cd n2, since when i try to create a usb drive it doesnt accept user cd as the second cd.
                      • Synthohol
                        • 5891
                        must only come with the fiery itself i imagine
                        what version was originally on it?
                        • Synthohol
                          • 5891
                          ok so i decompressed the iso and in the folder is system.efi and system2.efi
                          im curious if you burn the system2.efi to a second dvd if it is what its looking for?
                          i wish i could go where i used to work and try these scenarios, i really enjoyed playing with fierys.
                          so much that i have 5 running in my house i converted into servers and workstations.
                          if i could have gotten my ic-306s to take system software without that second disk i would have sold them.
                          • senchi
                            • Jun 2020
                            • 16
                            we must be the same, lol, since i am using an ic414 as a hdd cloning tool using pxe. as for your suggestion i think that in cd 2 there must be a system3.efi, because when i run the setup from the computer, the installation process is split into three stages, and it asks for a 2nd dvd before the third stage. But it is weird for konica to not provide this dvd if it indeed comes with the machine. The fiery is on site and i dont actually have one to play and fool with custom isos right now.
                            • wjurls
                              • Feb 2017
                              • 501
                              I have tried unsuccessfully a few times to clone the image of a system disk 2. Disk 2 contains the Windows operating system which is why you can't download it. I wish they would at least offer the option to pay for an image of it with a license code for those that lose, or damage the originals.
