Bizhub C250i Doesnt boot properly after sleep mode
  • tekkie
    • Mar 2011
    • 114
    [Misc] Bizhub C250i Doesnt boot properly after sleep mode
    Hi Guys
    I have an issue with a Bizhub C250i that doesnt always wake up after going in to sleep mode.
    I have upgraded firmware to latest version and am waiting to see if problem is resolved but would appreciate advice.
    The majority of the time the customer goes to the mc when its in sleep mode and touches the screen or button at side and it wakes up ok but 3 or 4 times a day it doesnt it just sits waiting and in the end the customer has to power down completely and switch back on.
    Its same in print mode sometimes the print job doesnt wake mc up
  • tsbservice
    Field tech
    • 8076
    Re: Bizhub C250i Doesnt boot properly after sleep mode
    Hi tekkie, you can try settings below:
    [Power Consumption in Sleep Mode] - Disabled
    [Power Save Settings] - Sleep
    [Enter Power Save Mode] - Normal
    [Power Key Setting] - Power Save
    • strider5555
      • Jun 2008
      • 96
      I also had this issue on a C550i. Latest firmware (at the time was G00-E9) Did all the recommended settings plus a few i found on this site. In the end I wiped the machine to factory, restored all the customer settings. I also disabled IPv6, had the IT set the port to raw instead of LPR,(or vice versa) i don't remember which way it was set to originally. I also did the recommended settings to disable sleep mode and also to turn off the weekly timer setting, which is on by default for some reason. The customer has not called back with this issue since.
      • kingarthur
        • 1399
        Standard procedure for every machine set up
        • Gift
          • Mar 2011
          • 2459
          + check if the nVME phison FW needs an update, there's a recent discussion about this here around
          • suomi
            • Oct 2008
            • 155
            you have also displayed everything about the service mode?
            K8 Firmware?
            • tekkie
              • Mar 2011
              • 114
              K8 Firmware?
              Yes its K8 firmware
              • copyman
                Owner / Technician
                • Sep 2005
                • 4787
                Seems Konica Minolta models have had trouble waking up for many years now. Even with the "4" series it was a big issue and we turned off sleep on every machine when it was setup out of box. Machine still goes into energy save mode saving electricity.
                Think they would of fixed this issue by now....
                • suomi
                  • Oct 2008
                  • 155
                  Service mode Sleep On/Off Choice settings (System 1)
                  To Display the option of "No" for the (sleep Mode Setting) screen available from (administrator > Maintanance > Timer Setting > Power Settings.
                  Network speed setting Auto >> 10/100
                  • dacam20590
                    • May 2019
                    • 31
                    i also have problem with bizhub 550i. how did you solve it
