Bizhub 4050 firmware information ?
  • Erwan
    • Nov 2021
    • 16
    [Misc] Bizhub 4050 firmware information ?
    Hi,
    End user on my side of a Bizhub 4050, i would like to know how to read the actual firmware information and how to update it if a newer one exists.
    Thanks in advance for your help.
    • 23009
    Re: Bizhub 4050 firmware information ?
    Advise endusers not to attempt updating firmware. If the machine is not working the way they want it to, then updating firmware by a technician is advised.
    For a person familiar with updating the firmware the most likely outcome is no-change in performance. The second most likely outcome is to brick the machine. The third most likely outcome is reduced functionality.
    For a person unfamiliar with updating firmware the most likely outcome is to brick the machine.
    • Erwan
      • Nov 2021
      • 16
      Hi,
      @blackcat4866, thanks for your reply and warning regarding firmware update on my own.
      I'm fully aware of the risks.
      I would like in the first place as stated to know which firmware version is installed on my Bizhub 4050 via the control panel, then forward the version to the community and "maybe or maybe not" trying to update it with the help of the community and with the appropriate procedures.
      Thanks all for your reply.
      • Erwan
        • Nov 2021
        • 16
        Hi,
        I was able to find this on my own
        Am i up to date ? or a newer version is available ? If so where to find it ?
        Thanks.
          • 23009
          There is a version 13: G0B-W99 Controller, newer than yours.
          And I will repeat: If the machine works, there is no need to update ... unless you were hoping for a brick. =^..^=
          • tsbservice
            Field tech
            • 8020
            Originally posted by Erwan
            Hi,
            Ultimately what is your goal? I'm sorta firmware update obcessed junky but most folks here like the approach - keep it simple working or Kiss and it works 99+%
            • Erwan
              • Nov 2021
              • 16
              @blackcat4866,
              Thanks for your reply, as i already save the printer from being destroyed initially, i don't mind to brick !
              If you want to share the newer version with me, it will be great otherwise...
              Thanks.
                • 23009
                Sorry, you'll have to find someone else to help you brick the machine. I won't do it, for your own good. =^..^=
                • Erwan
                  • Nov 2021
                  • 16
                  @tsbservice, @blackcat4866,
                  Yes the equipment works fine with the actual firmware !
                  On the other side, why the manufacturer delivers new firmware then if not to resolve bug, improve the equipment, fight the planned obsolescense etc...
                  Thanks for your help anyway !
                  • emujo2
                    • Mar 2017
                    • 1579
                    Cat is correct..these are not KM devices, but lexmarks..firmware is Engine, controller, and web browser/non web browser. Each firmware must be put on in a very particular step by step or as he mentioned you get a brick..Maybe you could post what you are trying to accomplish..I have trained techs that screw this up from time to time. E
                    • Erwan
                      • Nov 2021
                      • 16
                      @emujo2,
                      can you explain me how it could be a lexmark equipment as i just take this picture:
                      • copier tech
                        • 8174
                        Hi,
                        Happy to help you with the latest firmware & service manual should you still require it.
                        • Erwan
                          • Nov 2021
                          • 16
                          Hi @copier tech,
                          Thanks for your help, is it free of charge ? if yes cool, your help will be appreciate, if not...
                          • emujo2
                            • Mar 2017
                            • 1579
                            @emujo2,
                            many vendors sell other manufactures equipment with their name on it, this just happens to be a Lexmark device with a KM badge on it. Auto dealers do the same thing..
                            • tsbservice
                              Field tech
                              • 8020
                              I've heard French techs are really helpful. Makes me wonder why his woes aren't answered...
