Bizhub C558
  • vr4fiji
    • May 2014
    • 8
    Bizhub C558
    I have C558 machine that had color issue. black and cyan is totally missing from test pattern
    TCR level is not stable on cyan and black
    manual add toner the TCR will hit 6 to 7% margin but drop to 0 went stabilize
  • copyman
    Owner / Technician
    • Sep 2005
    • 4676
    Re: Bizhub C558
    What are the life counters at?
    Remove drums and with flashlight look at developer units and see if all 4 mag rollers have developer on them? Compare K & C mag rollers to the 2 colors that are showing on test page.
    Did you run any test sheets in service mode?
    • DK-tech
      • Apr 2021
      • 25
      Re: Bizhub C558
      I have changed the sub hopper assy on these before. Make sure the hopper is actually working correctly or change it.
      • Cantechman
        • Nov 2008
        • 228
        Re: Bizhub C558
        High voltage board maybe? I had a issue on that model before where black was just a very light grey and it was the HV board.
        • Albonline
          • Sep 2008
          • 1147
          Re: Bizhub C558
          Are the developer units exchanged from another copier?
          • progoffice
            • Nov 2008
            • 334
            Re: Bizhub C558
            I had this happen on a C458 (yellow), and it was because the drum unit was no longer turning. There was a huge amount of toner to clean up inside the machine - so if you didn't see that this might not be your problem.
            • vr4fiji
              • May 2014
              • 8
              Re: Bizhub C558
              Yes it happens on Cyan..the waste box is full of cyan toner n plus also inside the machine
              i have change mfp board hv and ih board even the expansion board
