Is TN321 powder compatible with Konica Minolta C250i
  • CSSI
    • Dec 2021
    • 1
    Hello ,
    I have excess stock of TNH 321 (C364e) toner, my question is: can I reuse the powder to refill empty C250i toners?
    Is the powder quality same ?
    such as Konica C250i toner have a counter chip and it will be detected as filled but can the machine use 0 counter toner any way ?
    Thank you advance.
    Re: Is TN321 powder compatible with Konica Minolta C250i
    Originally posted by CSSI
    Hello ,
    Thank you advance.
    Check the formula specs on the side of the box.
    • kingarthur
      • 1399
      You can check the MSDS sheet
      • emujo2
        • Mar 2017
        • 1579
        I have put 322 into C360I with no ill affects, and I have put 8 series color into a C364. no change in the quality..The only thing you want to avoid is toner with added developer. E
        • tsbservice
          Field tech
          • 8082
          8 series, 4 series all toners have added developer...what you're talking about?
          • copier tech
            • 8237
            Hello ,
            Thank you advance.
            Yes Konica Minolta seem to use identical toner throughout the office range from as far back as the 3 series to current i series.
            As an example I've been decanting old C552 drum unit developer & storing it to top up 4e series developer units when they start depleting.
