Help firmware 758
  • Abdo98
    • Jun 2019
    • 61
    Help firmware 758
    Hi
    I need firmware konica minlota 758
  • Synthohol
    Certified Konica Expert
    • 5799
    Re: Help firmware 758
    wish i could help but there is no 758 in the US catalog of models.
    maybe someone across the great pond can help?
    • Abdo98
      • Jun 2019
      • 61
      Thanks bro
      • tsbservice
        Field tech
        • 7975
        Aren't 758/808/958 firmware same series identical?
        • copier tech
          • 8132
          Originally posted by Abdo98
          Hi
          We are happy to help.
          Printer & Copier Firmware - www.printerfirmware.co.uk
          • Synthohol
            • 5799
            When I type in a model all available models show in the drop down but as soon as I hit the 8 at the end no results found.
            Not avail in the US market.
            • tsbservice
              Field tech
              • 7975
              I know US market don't have 758 model and also know what You mean searching by model in MKM. My point was it is the same FW0004 folder for 3 758/808/958 machines therefore you have FW for 958 which also fits 758(same firmware). For example you have same firmware for C258/308/368. I hope you have great weekend Synt
              • copier tech
                • 8132
                Maybe it's a European model.
                Bizhub Mono 758 pro 958 Firmware Readme GCA-Y1.pdf
                • tsbservice
                  Field tech
                  • 7975
                  [ATTACH]51059[/ATTACH]
                  Doesn't matter European or not firmware should be the same.
                  • copier tech
                    • 8132
                    Correct.
                    • Synthohol
                      • 5799
                      PM sent for the 808 version.
