Getting an orange-yellowish line on pr1nt (posted on behalf of diwaker)
  • Synthohol
    Certified Konica Expert
    • 5816
    diwakar 2 Attachment(s)
    Getting an orange-yellowish line on print
    Hello All !
    We are getting a yellow-ish line towards the centre on our 12x18 prints. What can be the cause ? Attached screenshot
    Printer: Konica C258
    Paper: 12x18 300 GSM Art Card
    DPI: 1200
    Tray: Bypass
    Thank you for your help :-)
    Attachment 51062Attachment 51063
  • Synthohol
    • 5816
    Re: Getting an orange-yellowish line on pr1nt (posted on behalf of diwaker)
    its not a yellow/orange issue. you are missing cyan and or black.
    check laser slit glass and DV coverage. could be debris behind a doctor blade on one of the DV units
    • tsbservice
      Field tech
      • 8006
      At max paper weight consumables life is critical. Post them plus are you using compatible toner?
      • Synthohol
        • 5816
        i hope he sees this thread and not just kept the "print" one open in his browser hitting refresh every hour
        • TEST10
          • Jun 2010
          • 69
          I would check the cyan development unit, it must be rubbish
          • TEST10
            • Jun 2010
            • 69
            • diwakar
              • Aug 2019
              • 37
              Hello All !
              DPI: 1200
              Tray: Bypass
              Thank you very much for reposting :-)
              • diwakar
                • Aug 2019
                • 37
                Thanks for this, we will try it today, however, we cleaned the whole laser unit. We will check for DV units today
                • diwakar
                  • Aug 2019
                  • 37
                  We are using compatible toner and recently, the black OPC life was over, so we replaced the chip, and then it worked fine.
                  • diwakar
                    • Aug 2019
                    • 37
                    We will again check the cyan DV and all other DV units today and will post result.
                      Turd party toner is a nono.
                      The chip might get you some miles but will come back.
                      Is drum turd party also?
                      Might have missed it, but what are drum/dev counts?
                      • kingarthur
                        • 1344
                        Have you cleaned the PH unit with the wand, or have you removed it and cleaned it, sometimes using the wand isn't enough, you have to physically remove it and wipe the windows
