konicaMinolta BIZhub C250i/C300i
  • Rullo
    • Oct 2023
    • 4
    konica bizhub bizhub c250i 300i after toner replacement report printer works but toner level on display remains at 0%
    has anyone had these problems ?
    the only solution so far found was to reset via bit switch
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    if you use non-oem toner you will have damaged (bent or sunken) copper contacts touching the toner chip.
    Field technician since 1994
    • copyman
      Owner / Technician
      • Sep 2005
      • 4651
      Like other poster said aftermarket toners can cause issues like that, especially if they are refilled and chip not replaced. There is a setting in service mode that will reset toners back to full but should be done by a qualified technician.
      • Rullo
        • Oct 2023
        • 4
        the toners we use for our customers are original
        • mojorolla
          The Wolf
          • 2603
          Damaged or clogged up toner hopper unit, pretty common on this model.
          There are several posts on this site regarding this issue.
          • jwrycza
            Office Systems Expert
            • Sep 2013
            • 88
            Usually after 1 or 2 replenish cycles, the "gauges" catch up and they will be fine. They may have replaced them prematurely.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4651
              Sometimes turning off and on the "main" pwr sw will reset gauges. If not use the bit sw to reset gauges to full. The machine has to have the correct FW for bit sw to work. Think I recall seeing a bulletin about this issue.
