bizhub 287 marketplace off issues
  • brent
    • Nov 2008
    • 1214
    ok losing my mind. I have tried to go into admin network iws forward screen 3 times to marketplace off.. it still s hows up on the screen after a minute
    then I tried the 172 soft switch from 05 to 01 still not it.. any thoughts? also I passed it but to turn on consumables what soft switch? so I could view. thanks
    I may find it sooner then later its just got the best of me today thank you
    brent
  • Ziggy
    • Feb 2018
    • 801
    to show consumables set sw 227 to hex 00
    • tsbservice
      Field tech
      • 8051
      Try this:
      • [Utility]
        • [Administrator Settings]
          • [System Settings]
            • [Custom Display Settings]
              • [Main Menu Default Settings]
      • [Main Menu Key 11]: [ON]/[bizhub MarketPlace] (only on North America models)
      • brent
        • Nov 2008
        • 1214
        Try this:
        • [Utility]
            • [System Settings]
        I thought that was going to work. but it came back on ... darn it.. I think its a soft switch.. its already turned off in other settings yet it comes back on
        thanks
        • brent
          • Nov 2008
          • 1214
          dang upon closer look today there is no soft switch to turn off marketplace. this is wild I have already turned it off and was hoping to not to do a firmware update
          thanks to all that have helped me
          brent
          • brent
            • Nov 2008
            • 1214
            ok well I did find it.. under the reset settings system auto reset disable screen saver boom gets rid of the marketplace screen saver. even though marketplace was turned off there was no button on the screen even for marketplace once it was turned off in the network iws forward forward forward marketplace off.. setting... who knew.. lol anyways thanks all for some advice ...
            have a great day
            brent
