error d011 c308
  • romario
    • Jun 2020
    • 186
    error d011 c308
    i have this error d011 on my konica c308, i need the files
    1. A7PU0Y0-F000-GXX-A8
    2. A7PU0Y0-F000-GXX-B0
    can someone help me my email is
    romarioaparicio2@gmail.com
    thanks
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5777
    Re: error d011 c308
    CD011
    (1) Contents
    Trouble type CD011: Hard disk out of specifications mounted
    Rank C
    bizhub C368/C308/C258 K TROUBLESHOOTING > 3. TROUBLE CODE
    K-94
    Trouble detection
    condition
    A hard disk that falls outside the specifications is connected.
    Trouble isolation -
    Relevant electrical parts • Hard disk (A) (HDD (A))
    • Hard disk (B) (HDD (B): HD-524)
    (2) Procedure
    1. Check the hard disk specifications.
    2. Replace the hard disk. (HDD (A) / HDD (B))
    firmware likely wont do anything.
    is it the original HDD?
    if replaced, was it the same size/type?
    did you replace the SATA cable as well?
    did you try formatting it?
    just asking because you did not provide what you have done so far.
    • romario
      • Jun 2020
      • 186
      Re: error d011 c308
      Originally posted by Synthohol
      CD011
      (1) Contents
      Rank C
      K-94
      (2) Procedure
      sorry, if I change hdd 3 times, sata cable, update firmware A7PU0Y0-F000-GXX-B6 and follow the error, read here in the forum that with those files I solve the problem
      thanks
