bizhub c308 error D011
  • romario
    • Jun 2020
    • 192
    Someone who can help me with firmware file 1. A7pu0y0-f000-gxx-a8
    2. A7pu0y0-f000-gxx-b0
    start solving error d011, already change hdd, sata cable and continue with the problem
    thanks
  • femaster
    • May 2011
    • 1494
    Re: bizhub c308 error D011
    Is the hard drive the correct size (capacity) for the copier? See error info below. I've also attached a PDF for Konica's troubleshooting procedure. Hopefully you can read English without pushing it through a translator, or the PDF might not be much help to you...
    K.3.25.6. CD011 (bizhub C658/C558/C458/C368/C308/C258)
    Contents
    Trouble type CD011: Hard disk out of specifications mounted
    Rank C
    Trouble detection condition A hard disk that falls outside the specifications is connected.
    Trouble isolation -
    Relevant electrical parts
    • Hard disk (A) (HDD (A))
    • Hard disk (B) (HDD (B): HD-524)
    Procedure
    • Check the hard disk specifications.
    • Replace the hard disk.
    Trap_Code_C-Code_CD011.pdf
    • Synthohol
      Certified Konica Expert
      • 5814
      pm sent.
