Finisher FS-539/ FS-539 SD/ Punch Kit PK-524 Jamming at folding output tray
  • Otto Rheeney
    Average Printing Guy
    • Sep 2024
    • 20
    #16
    Originally posted by John Kaufmann
    Struggling to understand this problem over several days (and seeing others also struggle to define what exactly is the problem here), I try to strip the problem down to its essentials. In that regard, one element of my confusion is the reference to the punch kit (PK-524), because I don't see how that is related to anything. (Near as I can tell, it's not even used here.) At the risk of being simple-minded: What is its connection?
    Apologies, I don't have it installed on the machine.
    Not sure why I included it but, I only glanced across KM manuals online and saw the name given as is. It was the article with the different parts of the finisher; it said "Finisher FS-539/Punch kit (PK-524)".
    • Kenny
      • Jun 2009
      • 537
      #17
      we had this issue and it turned out to be the static brushes in the SD unit, replaced them and machine worked fine
      • Otto Rheeney
        • Sep 2024
        • 20
        #18
        Thanks for the insight.
        Would you have the part code or an image of it? That would really be appreciated
        • John Kaufmann
          • Sep 2013
          • 116
          #19
          Interesting! - always wondered how important those were. So is this problem more common when the office is dry (as in cold weather)?
          There must be five or six rails of those brushes. Did you replace all of them?
          • Kenny
            • Jun 2009
            • 537
            #20
            the machine was located next a huge window and you could feel the cold air passing through,
            we used this guide (Attached) we added the extra static brush and also replaced the one as soon as i enters the SD unit, there should be a black up/down guide next to it.
            the finisher would hardly jam when it was doing the crooked booklets but when it did it came up with 7286, slanted folders, stapled incorrectly..
