Finisher FS-539/ FS-539 SD/ Punch Kit PK-524 Jamming at folding output tray
  • Otto Rheeney
    Average Printing Guy
    • Sep 2024
    • 20
    [Jamming] Finisher FS-539/ FS-539 SD/ Punch Kit PK-524 Jamming at folding output tray
    Just wanted to know if there is a fix for continuous jamming at the folding output tray.
    I normally run booklets with the configuration seen below.
    WhatsApp Image 2025-03-14 at 09.26.21_96514a66.jpg WhatsApp Image 2025-03-14 at 09.26.20_2d4ff37f.jpg WhatsApp Image 2025-03-14 at 09.26.20_5c73b7fb.jpg
    The paper runs normally from the KM C360i to the finisher but, upon exiting the folding output tray it misaligns and folds wrongly. See below
    WhatsApp Image 2025-03-14 at 09.26.43_87f1ebae.jpg WhatsApp Image 2025-03-14 at 09.26.43_87f1ebae.jpg
    I'll link a video here that I captured on my phone.
    Technical advice is welcome.
    • 23010
    What jam codes?
    • femaster
      • May 2011
      • 1526
      You may have more than one problem going on here, or something completely different. We've had a few FS539SD finishers what would fold in the wrong location like you are seeing, but they were never folded crooked like your examples, so what I am about to say may not apply to your situation.
      For us, we found that the aligning plate (circled in red below) would end up in the wrong location and a half fold would be way off. What we found is that the alignment plate was not moving up and down on the shafts smoothly and would bind. This resulted in it stopping in the wrong location which then resulted in the fold also being in the wrong location. Lubricating the shafts (in yellow below) is what fixed the issue in our situation.
      Because yours is folded crooked as well, that may not work for you. I'd take a look at that alignment plate and see if perhaps something with it is broken or out of place.
      • femaster
        • May 2011
        • 1526
        What jam codes?
        Based on his video, it doesn't appear to be jamming, just folding crooked.
        • Tech09
          • Apr 2020
          • 148
          Something I've seen a couple of times, the "grippers" circled in red mount onto the two blue circles, one side may be popped out of the holder. This causes the "grippers" to only grab and hold one side of the paper which can cause the skew in the fold and the mis-centering of the fold.
          • Ziggy
            • Feb 2018
            • 810
            try replacing items 22 and 23 . I've had issues with folding that replacing these paddles fixed
            • Otto Rheeney
              • Sep 2024
              • 20
              I'll look into this. Not sure if our local printer vendors even sell these
              Many thanks for the insight
              • Otto Rheeney
                • Sep 2024
                • 20
                Thanks for the insight.
                I'll check it out
                • Otto Rheeney
                  • Sep 2024
                  • 20
                  What jam codes?
                  Now that I've witnessed the paper error for another time and have taken some photo evidence, I'll clue you in on the error code and others.
                  The error code shown was: 72-26.
                  I have not read the manual nor do I have access to it right now. I tried asking our administrator if the manual was stowed away somewhere but, they also did not have a single clue as to where it may be.
                  I only observed the output tray and took some photos of it. Following the on-screen instructions to remove the paper and giving guesses as to what may be wrong with it based on the information replied by some users in this post.
                  Apart form that pleas see below for the pictures taken.
                  WhatsApp Image 2025-03-24 at 13.02.29_e223c266.jpg WhatsApp Image 2025-03-24 at 13.02.30_e0b15550.jpg
                  The booklet came out malformed and had a small punctured area, formed by what I assume to be one of the gears or paddle assys.
                  Please also see the below document for the error code screen and on-screen instructions.
                  Message Shown after Error.pdf
                  • tsbservice
                    Field tech
                    • 8064
                    [ATTACH]n1608619[/ATTACH]
                    First picture. Anytime I see staples on machine like this makes me wonder...asking for troubles don' t you?
                    • Otto Rheeney
                      • Sep 2024
                      • 20
                      Sorry, I don't follow.
                      Should I not use the stapling function? Or are the staples I'm using the wrong size?
                      This booklet was about 8 A3 sheets of standard plain paper. That's the booklet with the least amount of sheets used.
                      Tested it with plain paper 1 - 3 sheets in size and nothing went wrong, even with 5 sheets of A3 paper.
                      • Ziggy
                        • Feb 2018
                        • 810
                        Is the paper set for the correct weight ?
                        • Otto Rheeney
                          • Sep 2024
                          • 20
                          Yes.
                          Currently using Datamax premium copy paper (80 gsm).
                          The setting on the Konica bizhub C360i states between (60 - 90 gsm) so, the paper i'm using is between the selected sheet weight.
                          • Ziggy
                            • Feb 2018
                            • 810
                            Ok , just covering all the bases
                            • John Kaufmann
                              • Sep 2013
                              • 116
                              Struggling to understand this problem over several days (and seeing others also struggle to define what exactly is the problem here), I try to strip the problem down to its essentials. In that regard, one element of my confusion is the reference to the punch kit (PK-524), because I don't see how that is related to anything. (Near as I can tell, it's not even used here.) At the risk of being simple-minded: What is its connection?
