Konica Minolta bizhub 4050 stuck on startup
  • informaticaoffice
    • Oct 2019
    • 13
    Hi everyone, I have two bizhub 4050 konica minolta stuck on the konica minolta logo screen. Do you know how I can fix it?
  • copyrooks
    • Oct 2013
    • 210
    My money is on a hdd to be replaced
    • informaticaoffice
      • Oct 2019
      • 13
      Thanks for the reply. Yes it is the hdd do you have an idea on how I can solve it I can format it from external. I tried hdd on another machine same problem. Can I clone it from another HDD?
      • Synthohol
        Certified Konica Expert
        • 5849
        just attach to a computer, go into computer management, disk manager, highlight all the partitions on the drive and delete them till no partitions. create a single partition and remove from the computer.
        install on copier, boot into service mode and do a logical format only.
        upon reboot make sure the HDD is set to installed and usually yells about animation guide missing.
        • informaticaoffice
          • Oct 2019
          • 13
          Do you know where the menu is to set to hdd installed?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4723
            Make a small donation to this website and request the service manual.
            • informaticaoffice
              • Oct 2019
              • 13
              Ok I'll do it, it seems like the least I could do
              • Synthohol
                • 5849
                can you boot into trouble reset then service mode from there?
                • informaticaoffice
                  • Oct 2019
                  • 13
                  Yes I can
                  • Synthohol
                    • 5849
                    check error/trouble codes, see what tests you can run, self diagnostics etc..
