Bizhub C258 CD050 and FA14
  • tsbservice
    Field tech
    • 7910
    I went today to this client on normal routine works (they have plenty machines).
    Found one sitting hopelessly with CD050 code. Upon reboot it cleared error so here I go decided to update the FW with latest I have GCC-X4(yes I know it's not base). It took a long time of machine to show FW update screen but eventually I pushed start. It succeeds on other FWs but failed on MFP at 20%. So here I go again and did only MFP update it took it. After restarting machine comes to Ready and works but I noticed that in Device info tab it shows function version 4.2(it already was it before) but no FW version is shown. In CE mode it shows all modules firmware versions but MFP card(it's empty).
    Now machine is working but I suspect HDD or other issue may bite me near future. Here I summon experienced.
    Beside steps found in AAS(I will try that anyways) what are your words of wisdom guys.
    It won't beat me for sure just doing some precaution steps
    As always Thanks for any insights.
    God bless you and Happy New Year!
  • copier tech
    • 8101
    Re: Bizhub C258 CD050 and FA14
    There is an SATA firmware for random CD-xxx & HDD error codes.
    C208 Series Misc HDD error code.pdf
    • tsbservice
      Field tech
      • 7910
      Ahh thanks for that. I forgot to mention in my OP that SATA controller is already at new version(ends in G00-04).
      • copier tech
        • 8101
        Could be a failing HDD.
        The function version will always show 4.2 unless you change SW25 to HEX B0
        • tsbservice
          Field tech
          • 7910
          Yes.
          And Yes I just mentioned it in case anyone asked about function version. As a rule of thumb all of mine machines have their functional version match their FW version.
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            I've had this happen more than once before, well sort of. Not the having to install the MFPB F/W by itself because it failed but the not showing of F/W version. The machine has always worked and as long as it works, I don't worry about it and haven't had to do anything else later on. I just figure it's some sort of glitch on displaying the F/W version and leave it alone since the machine works.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • tulintron
              • Jul 2014
              • 669
              Good morning everyone. I have C258 giving me FA14. I tried to follow bulletin 10072, but I am missing the fw sta G00-04 to downgrade.
              Without it, it is impossible to follow in the footsteps of the newsletter.
              Would anyone be available to help?
              Thanks.
              • tsbservice
                Field tech
                • 7910
                Thanks.
                You can try recovery procedure with GXX-A8 FW.
                • tulintron
                  • Jul 2014
                  • 669
                  Thanks for answering. I tried with A8 andB0, both without success. A789be didn't help me either.
                  I think I need this G00-04 SATA. downgrade seems necessary.
                  I already disconnected the HDD, but none of that gave me a positive result.
                  • Synthohol
                    Certified Konica Expert
                    • 5735
                    PM
                    • tulintron
                      • Jul 2014
                      • 669
                      Originally posted by Synthohol
                      PM
                      • tulintron
                        • Jul 2014
                        • 669
                        Sorted out!
                        Thanks to everyone who helped in any way.
                        • srvctec
                          • Oct 2009
                          • 827
                          Sorted out!
                          Well, what was the solution?
