Biz 4752
  • copyman
    Owner / Technician
    • Sep 2005
    • 4525
    Biz 4752
    I know the 4750 has a backup battery that goes bad and machine loses time/date. Does the 4752 also have a battery that keeps date & time? Looked at 4752 in shop but can't find a battery like I've replaced several times on the 4750?
    Thanks in advance
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5737
    is this a coin battery in a plastic shell?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4525
      Think that part of board is covered. I will remove board so I can get at battery. Thanks!
      • copyman
        Owner / Technician
        • Sep 2005
        • 4525
        Good reason I couldn't find the battery. The board in Synthohol pic looks the same but the battery on this Biz 4752 is behind a metal cover. You have to take side cover off to see metal cover top left (see pics). At least I didn't have to remove the board which would have been a real PIA.
        Hopefully this will help someone else when they need to change battery because of lost date & time, and rest assured battery will eventually die especially if left off for long period.
