KM C8000 stuck on start-up
  • supersean9
    • Jan 2022
    • 4
    My KM8000 is stuck on the boot screen "Please wait, starting system"
    Any ideas???
    Re: KM C8000 stuck on start-up
    Any ideas???
    HDD .. firmware... defective part.
    Can you give is the error code ( if any )
    • supersean9
      • Jan 2022
      • 4
      There is no code, won't boot that far. Will not allow access to diagnostics either. Just stuck on system starting screen. Tried resetting cables to HDD's, no change.
      • wjurls
        • Feb 2017
        • 490
        This typically happens when it can't find the HDD or NVRAM. Just hangs up and doesn't know what to do.
          Being an end user do you even know how to find that information?
          Cables? NO! Try to format the drive if it fails replace HDD.
          • lucky13
            • May 2008
            • 125
            just so were clear is it the C8000 printer control panel with bad boot screen or is it the Fiery print controller /command work station big silver box not booting
            asking for a friend ?
            • tulintron
              • Jul 2014
              • 669
              Any ideas???
              Model C7000 has a procedure to rename a firmware and turn on the printer with usb connected. The printer already starts the firmware update and solves this initialization problem.
              Model C8000 same year and same schedule. I believe it is the same procedure. Search on and you should find the solution
              • supersean9
                • Jan 2022
                • 4
                Update, the fix to this was resetting the HDD connections on the main board. Thank you, Sean
