Ok replaced all feed tires in feed section and cleaned it all. Worked fine for a couple of pages then started 20-20 jams again. All other trays work perfect. Low meter machine. Any ideas?
C659 jam 20-20
So was it jamming with that same 20-20 code before you replaced the feed tires or that 20-20 code began only after you replaced the parts, and I assume you mean jamming from tray #1? First, clean the vertical pass rollers with alcohol, you could also swap the one way bearing components from a working tray to see if that is it.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.com -
Did you clean the one ways that mate with pickup & feed rollers? Slide both one ways off shafts, put some alcohol on pin bearings inside, blow out with air. If real high meter may have to scuff up shafts where one ways sits.👍 1Comment
