Good successor for the BH-363/423 series
  • copyman
    Owner / Technician
    • Sep 2005
    • 4785
    #16
    Re: Good successor for the BH-363/423 series
    I will keep a look out for it but fortunately the most my customers machines are off is maybe a long 3 day weekend. All F/W up to date.
    • tsbservice
      Field tech
      • 8064
      #17
      Now I prefer to install GXM-M1 (The customized firmware that merged existing bugs).
      It includes fixed issue of GHV-M1 (After turning OFF/ON the Main Power, the entry screen of serial number may be displayed in English and the MFP may not start) plus more than 300 other bug fixes.
      • sanvicente
        • Aug 2011
        • 31
        #18
        Originally posted by Hansoon
        I've heard from a wholesaler that his might happen when the machine is longer without power. So typically when the machine is taken out of service and going into storage for a longer period.
        Hans
        • allan
          RTFM!!
          • 5462
          #19
          I have had good experiences with the 7 range. The drums goes past 400K if the customer does not bend the transfer roller guide removing a jam. Dev due to replenishing goes forever unless you use bad toner can go to 600K. Fusers don't scratch like the 3 series. I dislike the smaller screens.
          I have not seen fuser, drum or dev kits for these.
          Do they exist.
          Been using DV411 to replace over-toned or contaminated developer.
          Can still get plenty of 3 series machines in ZA mostly over 500K on the clock. About $170 as is and another $250 to replace all clutches, rollers, bushings and consumables required to get it to run proper.
          Whatever
