CREO IC-312 System Software Reload
  • Workflo
    Veteran Member
    • Apr 2021
    • 6
    [Dead] CREO IC-312 System Software Reload
    Greetings and a marvellous New Year to you all.
    Here's one from the Archives.
    I have a KM Press C1085, with a CREO IC-312 RIP.
    The RIP has become corrupted, so has been reloaded.
    However, the software is for the IC-309 and, once reloaded and ready, displays an image of the C1060/70.
    So, all I'm asking is.... Do I require anything else, or will this work, once I connect it back to the C1085?
    Thanks, in advance.
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: CREO IC-312 System Software Reload
    Reference
    CREO has released Version 2.0 software for the IC-309 (compatible with bizhub PRESS C1070, C1070P, C71hc, C1060) and IC-312 (compatible with bizhub PRESS C1100, C1085) controllers. Marketing Bulletin 16-GB-029 (see attached).
    Technicians can order the software CDs using standard ordering procedures. Note that both part numbers are required for the appropriate controller.
    IC-309
    IC-309 SW KKIT v2.0 p\n 634-00903A
    Creo Manager SW KIT p\n 634-00904B
    IC-312
    IC-312 SW KKIT v2.0 p\n 634-00900A
    This new version contains a number of significant enhancements including:
    APPE v3.4, CPSI 3020
    Adobe APPE and CPSI engines were upgraded, providing enhanced PDL processing reliability and accuracy, as well as enhanced spot color and transparency processing for PDF and PDF/VT jobs.
    Adobe Acrobat 11, PDFL 11
    Adobe processing infrastructure updated.
    Default PDF RIP
    Automatically process PDF jobs using Adobe APPE RIP.
    Creo Manager (Remote Site Manager)
    Provides the ability to view and manage jobs on multiple Creo servers in one window.
    FD-9
    Add support for the Konica Minolta FD-9 calibration device.
    Validation Tool
    Tool to ensure a high level of color accuracy for printed output.
    Finishers
    Add support for the following new finishers:
    LS-506 Stacker
    External finisher
    SD-513 Saddle Stitcher (includes the FD-504 Square Folding Unit, CR-101 Creaser Unit, TU-503 Trimmer Unit)
